Hi Brad,
For me it installs but gets errors when trying to run. I installed both to the default directories. I'm out of the office and using a XP box that happens to have VS2010 installed. I get Err1 twice and then Err2 and below is the text extracted from the Err2 text box.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at devDept.Eyeshot.Viewport.OnPaint(PaintEventArgs e) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Message: 2745 |
Date: 12/28/2011 |
Subject: Re: Machine Manager III beta ... (again) |
Brad,
Looks like something wigged out on my machine. I re-booted, and was able to install OK (after un-installing the previous version). However, it won't start up. It takes a loooooooong time for anything to display, then I get an error dialog "Machine Manager Detected an Error", "Value cannot be null. Parameter name: source". If I click Yes, then after it starts drawing the form, I am stuck with an endless stream of .NET error dialogs, complaining about an unhandled exception caused by a null object reference. Here's the "meat" of the error details:
Ray L.
> Hello Ray,
> I'm sure you have tried this, but perhaps run as administrator?
> Also, you can try the .MSI file by itself.
> Barring that, I uploaded the latest install package here in the group::
> http://f1.grp.yahoofs.com/v1/IFn7TlUnyCg1Fujy137MaW1pfMYWigDyJTl-rOKbTW029ZTZX-PwxtwrYNKJkuPwJwINfOasXEbrqW__jS6D5qeUsz-i-ZigsLdrgP-c3nG0X5PI/MM/Machine%20Manager%20III.zip
> In case SourceForge has not updated yet.
> Thanks again,
> Brad Murry
> > Brad,
> > Nope, no change.
> > Regards,
> > Ray L.
> > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote:
> > > Hello Ray
> > > I just added a prereq for the MSI version 4.5. It will likely prompt you to download this from Microsoft's site.
> > > KMotion uses Install Shield, and VS2008 uses MSI version 3.1 which I think is why the problem did not exist before.
> > > I have updated the install package, please re-download and let me know if that did the trick for you.
> > > Thanks for the feedback!
> > > -Brad Murry
> > > > Brad,
> > > > When I run Setup.exe, I get: "The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed. Contact your support personnel for assistance".
> > > > I had no trouble installing KMotion v428 immediately before this.
> > > > Regards,
> > > > Ray L.
> > > > > Mirroring DynoMotion's new version release we have Machine Manager available here::
> > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machine%20Manager%20III.zip/download
> > > > > While you do NOT need hardware to try it out, you will need to download the latest KMotion install (4.28).
> > > > > If you install both KMotion in the default location, MM3 is already configured, however if you do not you simply need to change a setting in the cofiguration XML.
> > > > > Let me know if there are any problems.
> > > > > -Brad Murry
Message: 2746 |
Date: 12/28/2011 |
Message: 2747 |
Date: 12/28/2011 |
Brad,
This sounds exactly like what I'm getting and described in my last post.
I don't have a board connected BTW.
Message: 2748 |
Date: 12/28/2011 |
Also, I dont have a KFLOP hooked up to this PC.
Troy
--- In DynoMotion@yahoogroups.com, "tmday7" <tmday@...> wrote:
> Hi Brad,
> After install i tried running MM3 and i get this first window....
> http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc
> Then i get a window outline full screen with my desktop showing thruw, after i minimize i get the above error again, next i maximize and get this error window,.....
> http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc
> this window will not go away. Still, MM3 looks nice :)
> HTH
> Troy
> > -Brad Murry
Message: 2750 |
Date: 12/28/2011 |
All I get after a WHITE display for a long time is a grey screen nothing else is displayed. The grey looking screen is like small tiles or fish scales.
Cheers
Bengt
Message: 2751 |
Date: 12/28/2011 |
Hmm... it all looks to be caused by(or by using) a fancy third party library I am using...
I am going to install this on a clean test box and see what is happening.
One other thing, it looks like nobody's spindle manager dialogs are populating with the default spindle.
Thanks for the patience and feedback everybody-
BRB
-Brad
> Troy
> --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote:
> > Hi Brad,
> > HTH
> > Troy
> > > -Brad Murry
Message: 2752 |
Date: 12/28/2011 |
Seems that an OpenGL 2.0 capable video card is required.
I will look into a resolution.
-Brad
> BRB
> -Brad
> > Troy
> > > Hi Brad,
> > > HTH
> > > Troy
> > > > -Brad Murry
Message: 2753 |
Date: 12/28/2011 |
Found out sumthin. When second window appears (the .NET window), drag .NET window away from the center Graphics Preview area of MM3 and then click Continue. If you move mouse over the Graphics Preview area the .NET window comes back.
Troy
> -Brad
> > BRB
> > -Brad
> > > Troy
> > > > Hi Brad,
> > > > HTH
> > > > Troy
> > > > > -Brad Murry
Message: 2754 |
Date: 12/28/2011 |
Not for me.... The .NET error window just keeps coming back over and over.... And the MM display is hosed - buttons on top of buttons and many other things drawn wrong.
Ray L.
> HTH
> Troy
> > -Brad
> > > BRB
> > > -Brad
> > > > Troy
> > > > > Hi Brad,
> > > > > HTH
> > > > > Troy
> > > > > > -Brad Murry
Message: 2760 |
Date: 12/29/2011 |
Hello Ray,
Try the new package and if you still have "display issues", try moving/stretching them around.
Unless you are using a very small monitor I think the problem might be low screen resolution from using Mach.
Thanks for the feedback,
Brad Murry
> Regards,
> Ray L.
> > HTH
> > Troy
> > > -Brad
> > > > BRB
> > > > -Brad
> > > > > Troy
> > > > > > Hi Brad,
> > > > > > HTH
> > > > > > Troy
> > > > > > > -Brad Murry
Message: 2764 |
Date: 12/29/2011 |
Brad,
I was seeing the same thing ray reported (window took 75 secs to open, then the continual error dialogs).
I just tried the version that you uploaded this morning -
This version simply hangs and never even gets to where it opens and paints the main window.
Dave
> Hello Ray,
> Brad Murry
> > Regards,
> > Ray L.
> > > HTH
> > > Troy
> > > > -Brad
> > > > > BRB
> > > > > -Brad
> > > > > > Troy
> > > > > > > Hi Brad,
> > > > > > > HTH
> > > > > > > Troy
> > > > > > > > -Brad Murry
Message: 2767 |
Date: 12/29/2011 |
Hello Dave, Can you give me some information about your PC? I have tested the install on a very underpowered netbook with good results.(it does take about ten seconds to load, but it is a netbook after all) You do have Kmotion4.28 installed yes? -Brad From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of mvcalypso Sent: Thursday, December 29, 2011 11:42 AM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Brad, I was seeing the same thing ray reported (window took 75 secs to open, then the continual error dialogs).
I just tried the version that you uploaded this morning - This version simply hangs and never even gets to where it opens and paints the main window.
Dave
--- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@...> wrote: > > Hello Ray, > > Try the new package and if you still have "display issues", try moving/stretching them around. > > Unless you are using a very small monitor I think the problem might be low screen resolution from using Mach. > > Thanks for the feedback, > Brad Murry > > --- In DynoMotion@yahoogroups.com, "himykabibble" <jagboy@> wrote: > > > > Not for me.... The .NET error window just keeps coming back over and over.... And the MM display is hosed - buttons on top of buttons and many other things drawn wrong. > > > > Regards, > > Ray L. > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > Found out sumthin. When second window appears (the .NET window), drag .NET window away from the center Graphics Preview area of MM3 and then click Continue. If you move mouse over the Graphics Preview area the .NET window comes back. > > > HTH > > > Troy > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > I will look into a resolution. > > > > > > > > -Brad > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy third party library I am using... > > > > > > > > > > I am going to install this on a clean test box and see what is happening. > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager dialogs are populating with the default spindle. > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > BRB > > > > > -Brad > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > Troy > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > Hi Brad, > > > > > > > After install i tried running MM3 and i get this first window.... > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop showing thruw, after i minimize i get the above error again, next i maximize and get this error window,..... > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > HTH > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have Machine Manager available here:: > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machine%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > If you install both KMotion in the default location, MM3 is already configured, however if you do not you simply need to change a setting in the cofiguration XML. > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2769 |
Date: 12/29/2011 |
Same here. It slurps up 145Mbytes of memory, but never actually displays anything.
Ray L.
--- In DynoMotion@yahoogroups.com, "mvcalypso" <dave@...> wrote:
> Brad,
> Dave
> > Hello Ray,
> > Brad Murry
> > > Regards,
> > > Ray L.
> > > > HTH
> > > > Troy
> > > > > -Brad
> > > > > > BRB
> > > > > > -Brad
> > > > > > > Troy
> > > > > > > > Hi Brad,
> > > > > > > > HTH
> > > > > > > > Troy
> > > > > > > > > -Brad Murry
Message: 2770 |
Date: 12/29/2011 |
I just refreshed the install package at sourceforge,
I had the window as hidden for debugging puroposes in the install but now the GUI will show.
Sorry about that....
-Brad
> Regards,
> Ray L.
> --- In DynoMotion@yahoogroups.com, "mvcalypso" <dave@> wrote:
> > Brad,
> > Dave
> > > Hello Ray,
> > > Brad Murry
> > > > Regards,
> > > > Ray L.
> > > > > HTH
> > > > > Troy
> > > > > > -Brad
> > > > > > > BRB
> > > > > > > -Brad
> > > > > > > > Troy
> > > > > > > > > Hi Brad,
> > > > > > > > > HTH
> > > > > > > > > Troy
> > > > > > > > > > -Brad Murry
Message: 2771 |
Date: 12/29/2011 |
Btad,
FWIW - Mine is just a plain-vanilla HP laptop, XP SP3, Intel Graphics. KMotion 4.28 installed yesterday.
Ray L.
> Hello Dave,
> -Brad
> Behalf Of mvcalypso
> Brad,
> the main window.
> Dave
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ,
> > Hello Ray,
> > Brad Murry
> > > Regards,
> > > Ray L.
> comes back.
> > > > HTH
> > > > Troy
> > > > > -Brad
> happening.
> > > > > > BRB
> > > > > > -Brad
> > > > > > > Troy
> > > > > > > > Hi Brad,
> window....
> 71/view?picmode=
> <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386
> 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc>
> 62/view?picmode=
> <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941
> 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc>
> > > > > > > > HTH
> > > > > > > > Troy
> > > > > > > > > -Brad Murry
Message: 2772 |
Date: 12/29/2011 |
Brad,
OK, now it comes up, but the display is still kinda hosed. Control overlaying other controls, controls off the bottom of the screen, etc. FRO and other controls on that "row" overlay the Z DRO, SpindleManager panel overlays the Z jogging control, and also extends beyond the bottom of the window, so gets clipped. But, it is up, and sort-kinda working....
Ray L.
> -Brad
> > Regards,
> > Ray L.
> > > Brad,
> > > Dave
> > > > Hello Ray,
> > > > Brad Murry
> > > > > Regards,
> > > > > Ray L.
> > > > > > HTH
> > > > > > Troy
> > > > > > > -Brad
> > > > > > > > BRB
> > > > > > > > -Brad
> > > > > > > > > Troy
> > > > > > > > > > Hi Brad,
> > > > > > > > > > HTH
> > > > > > > > > > Troy
> > > > > > > > > > > -Brad Murry
Message: 2773 |
Date: 12/29/2011 |
Just installed latest MM3 and all seems to be working. Installed fine. Started in about 5 seconds, no error windows and G Code Viewer is working.
This PC has no KFLOP and is a Dual Core 2.6ghz AMD with 4gb ram.
Troy
> > -Brad
> > > BRB
> > > -Brad
> > > > Troy
> > > > > Hi Brad,
> > > > > HTH
> > > > > Troy
> > > > > > -Brad Murry
Message: 2774 |
Date: 12/29/2011 |
Hi Ray, The default screen config was made on my dev laptop which has 1920x1200 resolution. While the controls are meant to stretch/scale, there are limits. I suspect you are using reduced resolution for Mach compatibility, if so you may need to stretch or rearrange the GUI to suit your needs. The only other option is more resolution. The control windows can be moved around and stretched/nested/tabbed in a similar fashion as you see in VS 2008/ VS 2010. HTH, Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble Sent: Thursday, December 29, 2011 12:09 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Brad,
Regards, Ray L.
--- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@...> wrote: > > > I just refreshed the install package at sourceforge, > > I had the window as hidden for debugging puroposes in the install but now the GUI will show. > > > Sorry about that.... > > > -Brad > > > --- In DynoMotion@yahoogroups.com, "himykabibble" <jagboy@> wrote: > > > > > > Same here. It slurps up 145Mbytes of memory, but never actually displays anything. > > > > Regards, > > Ray L. > > > > --- In DynoMotion@yahoogroups.com, "mvcalypso" <dave@> wrote: > > > > > > Brad, > > > I was seeing the same thing ray reported (window took 75 secs to open, then the continual error dialogs). > > > > > > I just tried the version that you uploaded this morning - > > > This version simply hangs and never even gets to where it opens and paints the main window. > > > > > > Dave > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > Hello Ray, > > > > > > > > Try the new package and if you still have "display issues", try moving/stretching them around. > > > > > > > > Unless you are using a very small monitor I think the problem might be low screen resolution from using Mach. > > > > > > > > Thanks for the feedback, > > > > Brad Murry > > > > > > > > --- In DynoMotion@yahoogroups.com, "himykabibble" <jagboy@> wrote: > > > > > > > > > > Not for me.... The .NET error window just keeps coming back over and over.... And the MM display is hosed - buttons on top of buttons and many other things drawn wrong. > > > > > > > > > > Regards, > > > > > Ray L. > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > Found out sumthin. When second window appears (the .NET window), drag .NET window away from the center Graphics Preview area of MM3 and then click Continue. If you move mouse over the Graphics Preview area the .NET window comes back. > > > > > > HTH > > > > > > Troy > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > > > > > I will look into a resolution. > > > > > > > > > > > > > > -Brad > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy third party library I am using... > > > > > > > > > > > > > > > > I am going to install this on a clean test box and see what is happening. > > > > > > > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager dialogs are populating with the default spindle. > > > > > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > > > > > BRB > > > > > > > > -Brad > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > > > Troy > > > > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > > > After install i tried running MM3 and i get this first window.... > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop showing thruw, after i minimize i get the above error again, next i maximize and get this error window,..... > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > > > HTH > > > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have Machine Manager available here:: > > > > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machine%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, MM3 is already configured, however if you do not you simply need to change a setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2775 |
Date: 12/29/2011 |
Excellent news, thanks for the feedback.
Looking forward to a hearing about jogging an axis!
-Brad
> Troy
> > > -Brad
> > > > BRB
> > > > -Brad
> > > > > Troy
> > > > > > Hi Brad,
> > > > > > HTH
> > > > > > Troy
> > > > > > > -Brad Murry
Message: 2776 |
Date: 12/29/2011 |
Hi Brad,
Still the same problem here
Cheers
Bengt
> -Brad
> > Regards,
> > Ray L.
> > > Brad,
> > > Dave
> > > > Hello Ray,
> > > > Brad Murry
> > > > > Regards,
> > > > > Ray L.
> > > > > > HTH
> > > > > > Troy
> > > > > > > -Brad
> > > > > > > > BRB
> > > > > > > > -Brad
> > > > > > > > > Troy
> > > > > > > > > > Hi Brad,
> > > > > > > > > > HTH
> > > > > > > > > > Troy
> > > > > > > > > > > -Brad Murry
Message: 2777 |
Date: 12/29/2011 |
Hello Bengt, By same problem you mean the GUI is not showing, but is in the processes in your Task Manager? -Brad From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Bengt Sjoelund Sent: Thursday, December 29, 2011 1:29 PM To: dynomotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Hi Brad, Still the same problem here Cheers Bengt
Message: 2778 |
Date: 12/29/2011 |
In files section look in my folder for My PC pdf file so you can see the specs
Cheers
Bengt
--- In DynoMotion@yahoogroups.com, "Bengt Sjoelund" <cnc@...> wrote:
> Hi Brad,
> Cheers
> Bengt
> > -Brad
> > > Regards,
> > > Ray L.
> > > > Brad,
> > > > Dave
> > > > > Hello Ray,
> > > > > Brad Murry
> > > > > > Regards,
> > > > > > Ray L.
> > > > > > > HTH
> > > > > > > Troy
> > > > > > > > -Brad
> > > > > > > > > BRB
> > > > > > > > > -Brad
> > > > > > > > > > Troy
> > > > > > > > > > > Hi Brad,
> > > > > > > > > > > HTH
> > > > > > > > > > > Troy
> > > > > > > > > > > > -Brad Murry
Message: 2779 |
Date: 12/29/2011 |
Hi brad,
Yep, Kmotion is installed - ver is the one I got from yesterdays release notices. No kflop hdw on the PC.
PC is Core 2 Duo, E7400 CPU @ 12.8Ghz, 3.4 GB Ram, Win XP SP3, all patches up to date. Video is set up with two cards running 2 monitors.
Dave
> Hello Dave,
> -Brad
> Behalf Of mvcalypso
> Brad,
> the main window.
> Dave
> > Hello Ray,
> > Brad Murry
> > > Regards,
> > > Ray L.
> comes back.
> > > > HTH
> > > > Troy
> > > > > -Brad
> happening.
> > > > > > BRB
> > > > > > -Brad
> > > > > > > Troy
> > > > > > > > Hi Brad,
> window....
> 71/view?picmode=
> 62/view?picmode=
> > > > > > > > HTH
> > > > > > > > Troy
> > > > > > > > > -Brad Murry
Message: 2781 |
Date: 12/29/2011 |
I forgot to say that both monitors are set to 1280.1024 on 3:4 aspect monitors
Dave
> Hi brad,
> Dave
> --- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@> wrote:
> > Hello Dave,
> > -Brad
> > Behalf Of mvcalypso
> > Brad,
> > the main window.
> > Dave
> > > Hello Ray,
> > > Brad Murry
> > > > Regards,
> > > > Ray L.
> > comes back.
> > > > > HTH
> > > > > Troy
> > > > > > -Brad
> > happening.
> > > > > > > BRB
> > > > > > > -Brad
> > > > > > > > Troy
> > > > > > > > > Hi Brad,
> > window....
> > 71/view?picmode=
> > 62/view?picmode=
> > > > > > > > > HTH
> > > > > > > > > Troy
> > > > > > > > > > -Brad Murry
Message: 2782 |
Date: 12/29/2011 |
It works for you now right? -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of mvcalypso Sent: Thursday, December 29, 2011 1:47 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) I forgot to say that both monitors are set to 1280.1024 on 3:4 aspect monitors
Dave
--- In DynoMotion@yahoogroups.com, "mvcalypso" <dave@...> wrote: > > Hi brad, > Yep, Kmotion is installed - ver is the one I got from yesterdays release notices. No kflop hdw on the PC. > > PC is Core 2 Duo, E7400 CPU @ 12.8Ghz, 3.4 GB Ram, Win XP SP3, all patches up to date. Video is set up with two cards running 2 monitors. > > Dave > > > > --- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@> wrote: > > > > Hello Dave, > > > > > > > > Can you give me some information about your PC? I have tested the install > > on a very underpowered netbook with good results.(it does take about ten > > seconds to load, but it is a netbook after all) > > > > > > > > You do have Kmotion4.28 installed yes? > > > > > > > > -Brad > > > > > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > > Behalf Of mvcalypso > > Sent: Thursday, December 29, 2011 11:42 AM > > To: DynoMotion@yahoogroups.com > > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > > > > > > > Brad, > > I was seeing the same thing ray reported (window took 75 secs to open, then > > the continual error dialogs). > > > > I just tried the version that you uploaded this morning - > > This version simply hangs and never even gets to where it opens and paints > > the main window. > > > > Dave > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > > "bradodarb" <bradodarb@> wrote: > > > > > > Hello Ray, > > > > > > Try the new package and if you still have "display issues", try > > moving/stretching them around. > > > > > > Unless you are using a very small monitor I think the problem might be low > > screen resolution from using Mach. > > > > > > Thanks for the feedback, > > > Brad Murry > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > > "himykabibble" <jagboy@> wrote: > > > > > > > > Not for me.... The .NET error window just keeps coming back over and > > over.... And the MM display is hosed - buttons on top of buttons and many > > other things drawn wrong. > > > > > > > > Regards, > > > > Ray L. > > > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > > , "tmday7" <tmday@> wrote: > > > > > > > > > > Found out sumthin. When second window appears (the .NET window), drag > > .NET window away from the center Graphics Preview area of MM3 and then click > > Continue. If you move mouse over the Graphics Preview area the .NET window > > comes back. > > > > > HTH > > > > > Troy > > > > > > > > > > --- In DynoMotion@yahoogroups.com > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > > > I will look into a resolution. > > > > > > > > > > > > -Brad > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy third > > party library I am using... > > > > > > > > > > > > > > I am going to install this on a clean test box and see what is > > happening. > > > > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager dialogs > > are populating with the default spindle. > > > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > > > BRB > > > > > > > -Brad > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > > Troy > > > > > > > > --- In DynoMotion@yahoogroups.com > > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > > After install i tried running MM3 and i get this first > > window.... > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/12193862 > > 71/view?picmode= > > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386 > > 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop > > showing thruw, after i minimize i get the above error again, next i maximize > > and get this error window,..... > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/13029410 > > 62/view?picmode= > > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941 > > 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > > HTH > > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have Machine > > Manager available here:: > > > > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machin > > e%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will need > > to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, MM3 is > > already configured, however if you do not you simply need to change a > > setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2784 |
Date: 12/29/2011 |
OK, downloaded version w/o the window hidden - so I see it load now.
That gets us past the no go stage - Later I'll start playing and see what I can break <grin>
Dave
> Dave
> > Hi brad,
> > Dave
> > > Hello Dave,
> > > -Brad
> > > Behalf Of mvcalypso
> > > Brad,
> > > the main window.
> > > Dave
> > > > Hello Ray,
> > > > Brad Murry
> > > > > Regards,
> > > > > Ray L.
> > > comes back.
> > > > > > HTH
> > > > > > Troy
> > > > > > > -Brad
> > > happening.
> > > > > > > > BRB
> > > > > > > > -Brad
> > > > > > > > > Troy
> > > > > > > > > > Hi Brad,
> > > window....
> > > 71/view?picmode=
> > > 62/view?picmode=
> > > > > > > > > > HTH
> > > > > > > > > > Troy
> > > > > > > > > > > -Brad Murry
Message: 2785 |
Date: 12/29/2011 |
I noticed that the Memory Usage is about 135 mb, is this normal? Seems high.
Ill let you know about actually moving machine:) I have never configured anything besides Mach3 to control machine.
Troy
> -Brad
> > Troy
> > > > -Brad
> > > > > BRB
> > > > > -Brad
> > > > > > Troy
> > > > > > > Hi Brad,
> > > > > > > HTH
> > > > > > > Troy
> > > > > > > > -Brad Murry
Message: 2786 |
Date: 12/29/2011 |
Hello Troy, After simulating a few 3d gcode programs MM went up to about 127 mb and after about a minute is back down to 120~ish. I have no Kflop connected, so it is likely higher once it is. For giggles I ran Mach alongside it and it pretty much stayed at around 97 mb. I think MM will use a varying amount of resources depending on things like CPU cores available and video hardware. That said, I’m sure there are ton of optimizations I can do to make it leaner/meaner. So I think 135 mb is ok, what to look out for is a memory leak which will cause the memory to climb higher and higher without really going down. I have not seen a memory leak yet. -Brad From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of tmday7 Sent: Thursday, December 29, 2011 2:22 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) I noticed that the Memory Usage is about 135 mb, is this normal? Seems high. Ill let you know about actually moving machine:) I have never configured anything besides Mach3 to control machine.
Thanks, Troy
--- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@...> wrote: > > Excellent news, thanks for the feedback. > > Looking forward to a hearing about jogging an axis! > > -Brad > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > Just installed latest MM3 and all seems to be working. Installed fine. Started in about 5 seconds, no error windows and G Code Viewer is working. > > This PC has no KFLOP and is a Dual Core 2.6ghz AMD with 4gb ram. > > Troy > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > I will look into a resolution. > > > > > > > > -Brad > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy third party library I am using... > > > > > > > > > > I am going to install this on a clean test box and see what is happening. > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager dialogs are populating with the default spindle. > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > BRB > > > > > -Brad > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > Troy > > > > > > --- In DynoMotion@yahoogroups.com, "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > Hi Brad, > > > > > > > After install i tried running MM3 and i get this first window.... > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop showing thruw, after i minimize i get the above error again, next i maximize and get this error window,..... > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > HTH > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com, "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have Machine Manager available here:: > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machine%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > If you install both KMotion in the default location, MM3 is already configured, however if you do not you simply need to change a setting in the cofiguration XML. > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2788 |
Date: 12/29/2011 |
Ok. Ill keep an eye on it once i figure out how to configure MM3 to run my mill. Do i configure KMotionCNC first, in order to get MM3 working?
Troy
> Hello Troy,
> mb.
> That said, I'm sure there are ton of optimizations I can do to make it
> leaner/meaner.
> -Brad
> Behalf Of tmday7
> Thanks,
> Troy
> > -Brad
> > > Troy
> > > > > -Brad
> happening.
> > > > > > BRB
> > > > > > -Brad
> > > > > > > Troy
> > > > > > > > Hi Brad,
> window....
> 71/view?picmode=
> 62/view?picmode=
> > > > > > > > HTH
> > > > > > > > Troy
> > > > > > > > > -Brad Murry
Message: 2789 |
Date: 12/29/2011 |
Hello Troy, KMotionCNC is an independent program and is not used in conjunction with MM3. There is a Configuration Editor that is nested in the same panel as the Gcode control by default. Within this control you can edit every aspect of MM. For a simple CNC setup you probably only need to edit the three axes, Interpreter and a spindle. From there, everything is setup via scripts that in Kflop’s case will fire off c programs much the same as you are already doing for things like homing, etc… Happy to help, Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of tmday7 Sent: Thursday, December 29, 2011 4:41 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Ok. Ill keep an eye on it once i figure out how to configure MM3 to run my mill. Do i configure KMotionCNC first, in order to get MM3 working? Thanks, Troy
--- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@...> wrote: > > Hello Troy, > > > > After simulating a few 3d gcode programs MM went up to about 127 mb and > after about a minute is back down to 120~ish. I have no Kflop connected, so > it is likely higher once it is. > > > > For giggles I ran Mach alongside it and it pretty much stayed at around 97 > mb. > > > > > > I think MM will use a varying amount of resources depending on things like > CPU cores available and video hardware. > > > > > > That said, I'm sure there are ton of optimizations I can do to make it > leaner/meaner. > > > > So I think 135 mb is ok, what to look out for is a memory leak which will > cause the memory to climb higher and higher without really going down. > > > > > > I have not seen a memory leak yet. > > > > -Brad > > > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > Behalf Of tmday7 > Sent: Thursday, December 29, 2011 2:22 PM > To: DynoMotion@yahoogroups.com > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > I noticed that the Memory Usage is about 135 mb, is this normal? Seems high. > Ill let you know about actually moving machine:) I have never configured > anything besides Mach3 to control machine. > > Thanks, > Troy > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "bradodarb" <bradodarb@> wrote: > > > > Excellent news, thanks for the feedback. > > > > Looking forward to a hearing about jogging an axis! > > > > -Brad > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "tmday7" <tmday@> wrote: > > > > > > Just installed latest MM3 and all seems to be working. Installed fine. > Started in about 5 seconds, no error windows and G Code Viewer is working. > > > This PC has no KFLOP and is a Dual Core 2.6ghz AMD with 4gb ram. > > > Troy > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > I will look into a resolution. > > > > > > > > > > -Brad > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy third > party library I am using... > > > > > > > > > > > > I am going to install this on a clean test box and see what is > happening. > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager dialogs > are populating with the default spindle. > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > BRB > > > > > > -Brad > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > Troy > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > After install i tried running MM3 and i get this first > window.... > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/12193862 > 71/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386 > 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop > showing thruw, after i minimize i get the above error again, next i maximize > and get this error window,..... > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/13029410 > 62/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941 > 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > HTH > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have Machine > Manager available here:: > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machin > e%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will need > to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, MM3 is > already configured, however if you do not you simply need to change a > setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2790 |
Date: 12/29/2011 |
Brad,
My display is 1280x900. I don't understand why the display won't properly size down to that without the controls getting so messed up. That's only about a 30% reduction.
Ray L.
> Hi Ray,
> resolution.
> HTH,
> Brad Murry
> Brad,
> Regards,
> Ray L.
> the GUI will show.
> > -Brad
> anything.
> > > Regards,
> > > Ray L.
> > > > Brad,
> > > > Dave
> > > > > Hello Ray,
> > > > > Brad Murry
> > > > > > Regards,
> > > > > > Ray L.
> window comes back.
> > > > > > > HTH
> > > > > > > Troy
> > > > > > > > -Brad
> is happening.
> > > > > > > > > BRB
> > > > > > > > > -Brad
> > > > > > > > > > Troy
> > > > > > > > > > > Hi Brad,
> window....
> 71/view?picmode=
> 62/view?picmode=
> > > > > > > > > > > HTH
> > > > > > > > > > > Troy
> > > > > > > > > > > > -Brad Murry
Message: 2791 |
Date: 12/30/2011 |
Hi Brad,
107megs in taskmanager, new file mm.png in my folder showing greyish fishscale like screen.
Cheers
Bengt
> Hello Bengt,
> your Task Manager?
> -Brad
> Hi Brad,
> Cheers
> Bengt
> the GUI will show.
> > -Brad
> anything.
> > > Regards,
> > > Ray L.
> > > > Brad,
> > > > Dave
> > > > > Hello Ray,
> > > > > Brad Murry
> > > > > > Regards,
> > > > > > Ray L.
> window comes back.
> > > > > > > HTH
> > > > > > > Troy
> > > > > > > > -Brad
> is happening.
> > > > > > > > > BRB
> > > > > > > > > -Brad
> > > > > > > > > > Troy
> > > > > > > > > > > Hi Brad,
> window....
> 71/view?picmode=
> 62/view?picmode=
> > > > > > > > > > > HTH
> > > > > > > > > > > Troy
> > > > > > > > > > > > -Brad Murry
Message: 2793 |
Date: 12/30/2011 |
Hello Bengt, The ‘scaled’ background is by design, however it looks like all of your controls are hidden. What happens when you goto view->display items at the top of the window? Are any of the items checked? If not when you check them they should pop up into view. Consider reinstalling from the sourceforge site to ensure you do have the latest build. -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Bengt Sjoelund Sent: Friday, December 30, 2011 2:45 AM To: dynomotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Hi Brad, 107megs in taskmanager, new file mm.png in my folder showing greyish fishscale like screen. Cheers Bengt
--- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@...> wrote: > > Hello Bengt, > > > > By same problem you mean the GUI is not showing, but is in the processes in > your Task Manager? > > > > -Brad > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > Behalf Of Bengt Sjoelund > Sent: Thursday, December 29, 2011 1:29 PM > To: dynomotion@yahoogroups.com > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > Hi Brad, > Still the same problem here > Cheers > Bengt > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "bradodarb" <bradodarb@> wrote: > > > > > > I just refreshed the install package at sourceforge, > > > > I had the window as hidden for debugging puroposes in the install but now > the GUI will show. > > > > > > Sorry about that.... > > > > > > -Brad > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "himykabibble" <jagboy@> wrote: > > > > > > > > > Same here. It slurps up 145Mbytes of memory, but never actually displays > anything. > > > > > > Regards, > > > Ray L. > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > , "mvcalypso" <dave@> wrote: > > > > > > > > Brad, > > > > I was seeing the same thing ray reported (window took 75 secs to open, > then the continual error dialogs). > > > > > > > > I just tried the version that you uploaded this morning - > > > > This version simply hangs and never even gets to where it opens and > paints the main window. > > > > > > > > Dave > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > Hello Ray, > > > > > > > > > > Try the new package and if you still have "display issues", try > moving/stretching them around. > > > > > > > > > > Unless you are using a very small monitor I think the problem might > be low screen resolution from using Mach. > > > > > > > > > > Thanks for the feedback, > > > > > Brad Murry > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "himykabibble" <jagboy@> wrote: > > > > > > > > > > > > Not for me.... The .NET error window just keeps coming back over > and over.... And the MM display is hosed - buttons on top of buttons and > many other things drawn wrong. > > > > > > > > > > > > Regards, > > > > > > Ray L. > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > Found out sumthin. When second window appears (the .NET window), > drag .NET window away from the center Graphics Preview area of MM3 and then > click Continue. If you move mouse over the Graphics Preview area the .NET > window comes back. > > > > > > > HTH > > > > > > > Troy > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > > > > > > > I will look into a resolution. > > > > > > > > > > > > > > > > -Brad > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy > third party library I am using... > > > > > > > > > > > > > > > > > > I am going to install this on a clean test box and see what > is happening. > > > > > > > > > > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager > dialogs are populating with the default spindle. > > > > > > > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > > > > > > > BRB > > > > > > > > > -Brad > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > > > > Troy > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > > > > After install i tried running MM3 and i get this first > window.... > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/12193862 > 71/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386 > 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop > showing thruw, after i minimize i get the above error again, next i maximize > and get this error window,..... > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/13029410 > 62/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941 > 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > > > > HTH > > > > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have > Machine Manager available here:: > > > > > > > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machin > e%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will > need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, > MM3 is already configured, however if you do not you simply need to change a > setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2794 |
Date: 12/30/2011 |
Hello Ray, The Interpreter Axis Manager control stretches but does not scale. I will see about making it scale. In the meantime if you drag it to it’s own column it should display correctly. -Brad From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of himykabibble Sent: Thursday, December 29, 2011 10:12 PM To: DynoMotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Brad,
Regards, Ray L.
--- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@...> wrote: > > Hi Ray, > > > > The default screen config was made on my dev laptop which has 1920x1200 > resolution. > > > > While the controls are meant to stretch/scale, there are limits. > > > > I suspect you are using reduced resolution for Mach compatibility, if so you > may need to stretch or rearrange the GUI to suit your needs. The only other > option is more resolution. > > > > The control windows can be moved around and stretched/nested/tabbed in a > similar fashion as you see in VS 2008/ VS 2010. > > > > HTH, > > Brad Murry > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > Behalf Of himykabibble > Sent: Thursday, December 29, 2011 12:09 PM > To: DynoMotion@yahoogroups.com > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > Brad, > > OK, now it comes up, but the display is still kinda hosed. Control > overlaying other controls, controls off the bottom of the screen, etc. FRO > and other controls on that "row" overlay the Z DRO, SpindleManager panel > overlays the Z jogging control, and also extends beyond the bottom of the > window, so gets clipped. But, it is up, and sort-kinda working.... > > Regards, > Ray L. > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "bradodarb" <bradodarb@> wrote: > > > > > > I just refreshed the install package at sourceforge, > > > > I had the window as hidden for debugging puroposes in the install but now > the GUI will show. > > > > > > Sorry about that.... > > > > > > -Brad > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > "himykabibble" <jagboy@> wrote: > > > > > > > > > Same here. It slurps up 145Mbytes of memory, but never actually displays > anything. > > > > > > Regards, > > > Ray L. > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > , "mvcalypso" <dave@> wrote: > > > > > > > > Brad, > > > > I was seeing the same thing ray reported (window took 75 secs to open, > then the continual error dialogs). > > > > > > > > I just tried the version that you uploaded this morning - > > > > This version simply hangs and never even gets to where it opens and > paints the main window. > > > > > > > > Dave > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > Hello Ray, > > > > > > > > > > Try the new package and if you still have "display issues", try > moving/stretching them around. > > > > > > > > > > Unless you are using a very small monitor I think the problem might > be low screen resolution from using Mach. > > > > > > > > > > Thanks for the feedback, > > > > > Brad Murry > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "himykabibble" <jagboy@> wrote: > > > > > > > > > > > > Not for me.... The .NET error window just keeps coming back over > and over.... And the MM display is hosed - buttons on top of buttons and > many other things drawn wrong. > > > > > > > > > > > > Regards, > > > > > > Ray L. > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > Found out sumthin. When second window appears (the .NET window), > drag .NET window away from the center Graphics Preview area of MM3 and then > click Continue. If you move mouse over the Graphics Preview area the .NET > window comes back. > > > > > > > HTH > > > > > > > Troy > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > > > > > > > I will look into a resolution. > > > > > > > > > > > > > > > > -Brad > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy > third party library I am using... > > > > > > > > > > > > > > > > > > I am going to install this on a clean test box and see what > is happening. > > > > > > > > > > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager > dialogs are populating with the default spindle. > > > > > > > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > > > > > > > BRB > > > > > > > > > -Brad > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > > > > Troy > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > > > > After install i tried running MM3 and i get this first > window.... > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/12193862 > 71/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386 > 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > > > > > > > Then i get a window outline full screen with my desktop > showing thruw, after i minimize i get the above error again, next i maximize > and get this error window,..... > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/13029410 > 62/view?picmode= > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941 > 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > > > > HTH > > > > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have > Machine Manager available here:: > > > > > > > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machin > e%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you will > need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, > MM3 is already configured, however if you do not you simply need to change a > setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2795 |
Date: 12/30/2011 |
Hi Brad,
All checked
This is the version here on Yahoo, expected it to be the latest version. Not good to have different versions all over :(
Will try to find my way to source.....
Cheers
Bengt
> Hello Bengt,
> The 'scaled' background is by design, however it looks like all of your
> into view.
> latest build.
> -Brad Murry
> Hi Brad,
> Cheers
> Bengt
> > Hello Bengt,
> in
> > your Task Manager?
> > -Brad
> > From: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> [mailto:DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ]
> On
> > To: dynomotion@yahoogroups.com <mailto:dynomotion%40yahoogroups.com>
> > Hi Brad,
> > Cheers
> > Bengt
> now
> > the GUI will show.
> > > -Brad
> displays
> > anything.
> > > > Regards,
> > > > Ray L.
> <mailto:DynoMotion%40yahoogroups.com> <mailto:DynoMotion%40yahoogroups.com>
> > > > > Brad,
> open,
> > > > > Dave
> > > > > > Hello Ray,
> might
> > > > > > Brad Murry
> > > > > > > Regards,
> > > > > > > Ray L.
> window),
> then
> > window comes back.
> > > > > > > > HTH
> > > > > > > > Troy
> > > > > > > > > -Brad
> what
> > is happening.
> > > > > > > > > > BRB
> > > > > > > > > > -Brad
> > > > > > > > > > > Troy
> > > > > > > > > > > > Hi Brad,
> > window....
> > 71/view?picmode=
> desktop
> maximize
> > 62/view?picmode=
> > > > > > > > > > > > HTH
> > > > > > > > > > > > Troy
> will
> a
> > > > > > > > > > > > > -Brad Murry
Message: 2796 |
Date: 12/30/2011 |
“Not good to have different versions all over :(“ True, but it should be current as well(Yahoo), just depends when you last downloaded. -Brad From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Bengt Sjoelund Sent: Friday, December 30, 2011 11:54 AM To: dynomotion@yahoogroups.com Subject: [DynoMotion] Re: Machine Manager III beta ... (again) Hi Brad, All checked This is the version here on Yahoo, expected it to be the latest version. Not good to have different versions all over :( Will try to find my way to source..... Cheers Bengt
--- In DynoMotion@yahoogroups.com, Brad Murry <bradodarb@...> wrote: > > Hello Bengt, > > > > The 'scaled' background is by design, however it looks like all of your > controls are hidden. > > > > What happens when you goto view->display items at the top of the window? > > > > Are any of the items checked? If not when you check them they should pop up > into view. > > > > Consider reinstalling from the sourceforge site to ensure you do have the > latest build. > > > > -Brad Murry > > > > From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On > Behalf Of Bengt Sjoelund > Sent: Friday, December 30, 2011 2:45 AM > To: dynomotion@yahoogroups.com > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > Hi Brad, > 107megs in taskmanager, new file mm.png in my folder showing greyish > fishscale like screen. > Cheers > Bengt > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , > Brad Murry <bradodarb@> wrote: > > > > Hello Bengt, > > > > > > > > By same problem you mean the GUI is not showing, but is in the processes > in > > your Task Manager? > > > > > > > > -Brad > > > > > > > > From: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > [mailto:DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ] > On > > Behalf Of Bengt Sjoelund > > Sent: Thursday, December 29, 2011 1:29 PM > > To: dynomotion@yahoogroups.com <mailto:dynomotion%40yahoogroups.com> > > Subject: [DynoMotion] Re: Machine Manager III beta ... (again) > > > > > > > > > > > > Hi Brad, > > Still the same problem here > > Cheers > > Bengt > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > <mailto:DynoMotion%40yahoogroups.com> , > > "bradodarb" <bradodarb@> wrote: > > > > > > > > > I just refreshed the install package at sourceforge, > > > > > > I had the window as hidden for debugging puroposes in the install but > now > > the GUI will show. > > > > > > > > > Sorry about that.... > > > > > > > > > -Brad > > > > > > > > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> > <mailto:DynoMotion%40yahoogroups.com> , > > "himykabibble" <jagboy@> wrote: > > > > > > > > > > > > Same here. It slurps up 145Mbytes of memory, but never actually > displays > > anything. > > > > > > > > Regards, > > > > Ray L. > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> <mailto:DynoMotion%40yahoogroups.com> > > , "mvcalypso" <dave@> wrote: > > > > > > > > > > Brad, > > > > > I was seeing the same thing ray reported (window took 75 secs to > open, > > then the continual error dialogs). > > > > > > > > > > I just tried the version that you uploaded this morning - > > > > > This version simply hangs and never even gets to where it opens and > > paints the main window. > > > > > > > > > > Dave > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > Hello Ray, > > > > > > > > > > > > Try the new package and if you still have "display issues", try > > moving/stretching them around. > > > > > > > > > > > > Unless you are using a very small monitor I think the problem > might > > be low screen resolution from using Mach. > > > > > > > > > > > > Thanks for the feedback, > > > > > > Brad Murry > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "himykabibble" <jagboy@> wrote: > > > > > > > > > > > > > > Not for me.... The .NET error window just keeps coming back over > > and over.... And the MM display is hosed - buttons on top of buttons and > > many other things drawn wrong. > > > > > > > > > > > > > > Regards, > > > > > > > Ray L. > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > Found out sumthin. When second window appears (the .NET > window), > > drag .NET window away from the center Graphics Preview area of MM3 and > then > > click Continue. If you move mouse over the Graphics Preview area the .NET > > window comes back. > > > > > > > > HTH > > > > > > > > Troy > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > Seems that an OpenGL 2.0 capable video card is required. > > > > > > > > > > > > > > > > > > I will look into a resolution. > > > > > > > > > > > > > > > > > > -Brad > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > Hmm... it all looks to be caused by(or by using) a fancy > > third party library I am using... > > > > > > > > > > > > > > > > > > > > I am going to install this on a clean test box and see > what > > is happening. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > One other thing, it looks like nobody's spindle manager > > dialogs are populating with the default spindle. > > > > > > > > > > > > > > > > > > > > Thanks for the patience and feedback everybody- > > > > > > > > > > > > > > > > > > > > BRB > > > > > > > > > > -Brad > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Also, I dont have a KFLOP hooked up to this PC. > > > > > > > > > > > Troy > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "tmday7" <tmday@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > Hi Brad, > > > > > > > > > > > > After install i tried running MM3 and i get this first > > window.... > > > > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/12193862 > > 71/view?picmode= > > > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1219386 > > 271/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > > > > > > > > > > > > > Then i get a window outline full screen with my > desktop > > showing thruw, after i minimize i get the above error again, next i > maximize > > and get this error window,..... > > > > > > > > > > > > > > > http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/13029410 > > 62/view?picmode= > > > <http://groups.yahoo.com/group/DynoMotion/photos/album/176979248/pic/1302941 > > 062/view?picmode=&mode=tn&order=ordinal&start=21&count=20&dir=asc> > > &mode=tn&order=ordinal&start=21&count=20&dir=asc > > > > > > > > > > > > this window will not go away. Still, MM3 looks nice :) > > > > > > > > > > > > HTH > > > > > > > > > > > > Troy > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In DynoMotion@yahoogroups.com > <mailto:DynoMotion%40yahoogroups.com> > > <mailto:DynoMotion%40yahoogroups.com> , "bradodarb" <bradodarb@> wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Mirroring DynoMotion's new version release we have > > Machine Manager available here:: > > > > > > > > > > > > > > > > > > > > > > > > > > > > > http://sourceforge.net/projects/cnctw/files/Machine%20Manager/Install/Machin > > e%20Manager%20III.zip/download > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > While you do NOT need hardware to try it out, you > will > > need to download the latest KMotion install (4.28). > > > > > > > > > > > > > > > > > > > > > > > > > > If you install both KMotion in the default location, > > MM3 is already configured, however if you do not you simply need to change > a > > setting in the cofiguration XML. > > > > > > > > > > > > > > > > > > > > > > > > > > Let me know if there are any problems. > > > > > > > > > > > > > > > > > > > > > > > > > > -Brad Murry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message: 2797 |
Date: 12/30/2011 |
Subject: Re: Machine Manager III beta ... (again) |
Hi Brad,
It is the one you put out a day or two ago.
Can this be that I use the Swedish version of W7?
You have at least install outside of the bloody *program*/*program files*/*program(X86)* shit and that is good!
Cheers
Bengt
> "Not good to have different versions all over :("
> downloaded.
> -Brad
> Hi Brad,
> All checked
> Cheers
> Bengt
> > Hello Bengt,
> up
> > into view.
> > latest build.
> > -Brad Murry
> On
> > Hi Brad,
> > Cheers
> > Bengt
> > > Hello Bengt,
> > in
> > > your Task Manager?
> > > -Brad
> > On
> > > Hi Brad,
> > > Cheers
> > > Bengt
> > now
> > > the GUI will show.
> > > > -Brad
> > displays
> > > anything.
> > > > > Regards,
> > > > > Ray L.
> > > > > > Brad,
> > open,
> and
> > > > > > Dave
> > > > > > > Hello Ray,
> > might
> > > > > > > Brad Murry
> over
> > > > > > > > Regards,
> > > > > > > > Ray L.
> > window),
> > then
> .NET
> > > window comes back.
> > > > > > > > > HTH
> > > > > > > > > Troy
> > > > > > > > > > -Brad
> > what
> > > is happening.
> > > > > > > > > > > BRB
> > > > > > > > > > > -Brad
> > > > > > > > > > > > Troy
> > > > > > > > > > > > > Hi Brad,
> first
> > > window....
> > > 71/view?picmode=
> > desktop
> > maximize
> > > 62/view?picmode=
> > > > > > > > > > > > > HTH
> > > > > > > > > > > > > Troy
> > will
> location,
> change
> > a
> > > > > > > > > > > > > > -Brad Murry
